HCL模拟器上的S6850交换机可以做irf堆叠吗,为什么一直堆叠不成功,命令没问题
(0)
可以
IRF需要严格根据官网文档步骤操作,配置步骤可以上来看下
(0)
#设备1 irf member 1 priority 32 int range Ten-GigabitEthernet 1/0/49 to Ten-GigabitEthernet 1/0/50 shutdown irf-port 1/1 port group interface Ten-GigabitEthernet1/0/49 port group interface Ten-GigabitEthernet1/0/50 int range Ten-GigabitEthernet 1/0/49 to Ten-GigabitEthernet 1/0/50 undo shutdown save irf-port-configuration active #设备2 irf member 1 renumber 2 int range Ten-GigabitEthernet 2/0/49 to Ten-GigabitEthernet 2/0/50 shutdown irf-port 2/2 port group interface Ten-GigabitEthernet2/0/49 port group interface Ten-GigabitEthernet2/0/50 int range Ten-GigabitEthernet 2/0/49 to Ten-GigabitEthernet 2/0/50 undo shutdown save irf-port-configuration active
把设备内存调整大一些试试
上配置看看
(0)
重启了,然后完成配置设备2就卡死了,设备1有这个日志IRF port 1 went down because the heartbeat timed out.
支持
检查下配置和相关输出进一步定位下吧
如下图
(0)
支持的,配置问题
(0)
#设备1 irf member 1 priority 32 int range Ten-GigabitEthernet 1/0/49 to Ten-GigabitEthernet 1/0/50 shutdown irf-port 1/1 port group interface Ten-GigabitEthernet1/0/49 port group interface Ten-GigabitEthernet1/0/50 int range Ten-GigabitEthernet 1/0/49 to Ten-GigabitEthernet 1/0/50 undo shutdown save irf-port-configuration active #设备2 irf member 1 renumber 2 int range Ten-GigabitEthernet 2/0/49 to Ten-GigabitEthernet 2/0/50 shutdown irf-port 2/2 port group interface Ten-GigabitEthernet2/0/49 port group interface Ten-GigabitEthernet2/0/50 int range Ten-GigabitEthernet 2/0/49 to Ten-GigabitEthernet 2/0/50 undo shutdown save irf-port-configuration active 这有问题吗
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
