S7503E V7版本 配置Portal 认证,原配置是V5的,按以下配置在V7的上面如何配
2018-09-27提问
  • 1收藏,1466浏览
粉丝:0人 关注:2人
这个是V5的软件版本上配置的,在V7的版本上面如何配置,按此配置刷进V7全部报错,
portal server sany ip 10.13.72.10 key sany url http://10.13.72.10:8080/protal
portal free-rule 0 source ip 10.13.72.10 mask 255.255.255.255 destination any
portal free-rule 1 source any destination ip 10.13.72.10 mask 255.255.255.255
portal free-rule 2 source any destination ip 10.13.72.9 mask 255.255.255.255
portal free-rule 3 source ip 10.13.72.9 mask 255.255.255.255 destination any
portal free-rule 6 source any destination ip 172.22.1.250 mask 255.255.255.255
portal free-rule 7 source ip 172.22.1.250 mask 255.255.255.255 destination any
portal free-rule 8 source any destination ip 172.22.1.33 mask 255.255.255.255
portal free-rule 9 source ip 172.22.1.33 mask 255.255.255.255 destination any
portal free-rule 10 source ip 10.0.3.6 mask 255.255.255.255 destination any
portal free-rule 11 source any destination ip 10.0.3.6 mask 255.255.255.255
 portal free-rule 12 source any destination ip 172.16.9.4 mask 255.255.255.255
portal free-rule 13 source ip 172.16.9.4 mask 255.255.255.255 destination any
portal free-rule 18 source ip 10.14.194.35 mask 255.255.255.255 destination any
portal free-rule 19 source ip 10.14.194.34 mask 255.255.255.255 destination any
portal free-rule 23 source ip 10.14.194.112 mask 255.255.255.255 destination any
portal free-rule 26 source ip 10.14.65.6 mask 255.255.255.255 destination any
portal free-rule 27 source ip 10.14.65.7 mask 255.255.255.255 destination any
portal free-rule 28 source ip 10.14.194.111 mask 255.255.255.255 destination any
portal free-rule 29 source ip 10.14.194.28 mask 255.255.255.255 destination any
portal free-rule 31 source ip 10.14.194.240 mask 255.255.255.255 destination any
由于是企业内网,部分地址段接入了IMC进行认证管理,
paul 九段
粉丝:30人 关注:5人
v5、v7的命令不一样,参考华三官网配置手册、有详细的配置命令介绍和举例。
举例上面给的不一样,能否给列举一条出来
勇往直前 发表时间:2018-09-27
1、portal server的配置拆为两个部分,类似下面: # 配置Portal认证服务器:名称为newpt,IP地址为192.168.0.111,密钥为明文portal,监听Portal报文的端口为50100。 [Switch] portal server newpt [Switch-portal-server-newpt] ip 192.168.0.111 key simple portal [Switch-portal-server-newpt] port 50100 [Switch-portal-server-newpt] quit # 配置Portal Web服务器的URL为http://192.168.0.111:8080/portal。(Portal Web服务器的URL请与实际环境中的Portal Web服务器配置保持一致,此处仅为示例) [Switch] portal web-server newpt [Switch-portal-websvr-newpt] url http://192.168.0.111:8080/portal [Switch-portal-websvr-newpt] quit 2、portal free-rule,试试先跟destination 再配置source ip
paul 发表时间:2018-09-27
