802.1x认证不通过
2018-12-21提问
  • 1收藏,1556浏览
进行远端802.1x认证,接入设备始终不和RADIUS服务交互报文。RADIUS服务器是我司IMC配置的。接入设备是HP 5130-24G-PoE+-4SFP+ (370W) EI。
接入设备能ping通服务器,接入设备上RADIUS配置没有问题。
RADIUS scheme name: 123
  Index: 4
  Primary Auth Server:
    Host name: Not Configured
    IP  : 20.1.1.1                                 Port: 1812   State: Active
    VPN : Not configured
  Primary Acct Server:
    IP  : 20.1.1.1                                 Port: 1813   State: Active
debugging RADIUS 后,没有产生RADIUS报文。
debugging  dot1x后,
*Jan  8 21:37:38:050 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] BE is in Idle state.
*Jan  8 21:37:38:050 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] PAE is in Aborting state.
*Jan  8 21:37:38:051 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] BE is in Initialize state.
*Jan  8 21:37:38:051 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] PAE is in Disconnect state.
*Jan  8 21:37:38:051 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] BE is in Idle state.
*Jan  8 21:37:38:052 2013 HP DOT1X/7/EVENT: PORT_SM[GE1/0/1] received event DOT1X_PSM_E_USER_UNAUTHORED.
*Jan  8 21:38:19:474 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] Processing new mac event .
*Jan  8 21:38:19:476 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] PAE is in Disconnect state.
*Jan  8 21:38:19:476 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] BE is in Initialize state.
*Jan  8 21:38:19:477 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] PAE is in Restart state.
*Jan  8 21:38:19:477 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] BE is in Idle state.
*Jan  8 21:38:19:478 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] PAE is in Connecting state.
*Jan  8 21:38:19:478 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] PAE is in Authenticating state.
*Jan  8 21:38:19:479 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] BE is in Request state.
*Jan  8 21:38:19:479 2013 HP DOT1X/7/EVENT: Sending EAP Packet (identifier 1, type 1)
*Jan  8 21:38:19:480 2013 HP DOT1X/7/PACKET:
所以为啥不能和服务器交互RADIUS报文?还有就是PAE,BE这些是啥,在配置指导上没有说过这些
墨峰 九段
粉丝:51人 关注:6人
同步一下交换机的配置。
怎么同步呢
一根大油条 发表时间:2018-12-24
把你的配置发出来。
墨峰 发表时间:2018-12-25
