现有一台36-40路由器,应用串口线管理。
设备内原有配置如下:
version 7.1.059, Release 0304P15
sysname name tdVPNwaiwang
password-recovery enable
vlan 1
controller Cellular0/0
controller Cellular0/1
interface Aux0
interface Ethernet2/0
port link-mode route
description to_jiansheyinhang
ip address 192.168.168.17 255.255.255.252
interface Ethernet2/2
description Link_to_nongyeyinghang
ip address 192.168.168.13 255.255.255.252
interface Ethernet2/3
description To_xinyongshe
ip address 192.168.168.5 255.255.255.252
interface Ethernet2/4
description To_gonghang
ip address 192.168.168.9 255.255.255.252
interface NULL0
interface Ethernet2/1
port link-mode bridge
interface Ethernet2/5
interface Ethernet2/6
interface Ethernet2/7
interface Ethernet2/8
interface GigabitEthernet0/0
description To_renhang
combo enable copper
ip address 192.168.168.1 255.255.255.252
interface GigabitEthernet0/1
combo enable copper
ip address 10.56.84.21 255.255.255.224
interface GigabitEthernet0/2
scheduler logfile size 16
line class aux
user-role network-admin
line class tty
user-role network-operator
line class vty
line aux 0
authentication-mode password
set authentication password hash $h$6$uSCYMsor3YZOiNHh$9QWnbSqU2VJ7B0jtt/SAJeeq
2rL4Y8f6Coi2u3kMjHcevX2sX+g2mvV6v9hX99zjLwb5ZQVl0vADNsnz1H0h1A==
line vty 0 63
ip route-static 145.0.241.0 24 192.168.168.18
ip route-static 192.168.1.0 30 192.168.168.2
ip route-static 192.168.2.0 24 192.168.168.6
ip route-static 192.168.3.0 24 192.168.168.10
ip route-static 192.168.4.0 24 192.168.168.14
ip route-static 192.168.5.0 24 192.168.168.18
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
return
现更换用途,清空原有配置,使用命令如下图:
现路由器无法正常启动,启动后超级终端显示内容如下:
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test
Do you want to check SDRAM? [Y/N]
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing....Done.
* H3C MSR36-40 BootWare, Version 1.43 *
Copyright (c) 2004-2015 Hangzhou H3C Technologies Co., Ltd.
Compiled Date : Apr 10 2015
CPU ID : 0x2
Memory Type : DDR3 SDRAM
Memory Size : 2048MB
BootWare Size : 1024KB
Flash Size : 8MB
cfa0 Size : 247MB
CPLD Version : 2.0
PCB Version : 2.0
BootWare Validating...
Image program does not exist.
Password recovery capability is enabled.
Note: The current operating device is cfa0
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Skip Authentication for Console Login |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
现请教处理方法,盼尽快回复,谢谢!
(0)
可以选择6跳过当前配置启动试一下
(0)
==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Enter your choice(0-9): 6 Flag Set Success. ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Enter your choice(0-9): 然后?
故障现象还在。。。。。。
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
