msr36-40疑似启动文件丢失
2019-01-15提问
  • 1收藏,1398浏览
现有一台36-40路由器,应用串口线管理。
设备内原有配置如下:
 version 7.1.059, Release 0304P15
 sysname name tdVPNwaiwang
 password-recovery enable
vlan 1
controller Cellular0/0
controller Cellular0/1
interface Aux0
interface Ethernet2/0
 port link-mode route
 description to_jiansheyinhang
 ip address 192.168.168.17 255.255.255.252
interface Ethernet2/2
 description Link_to_nongyeyinghang
 ip address 192.168.168.13 255.255.255.252
interface Ethernet2/3
 description To_xinyongshe
 ip address 192.168.168.5 255.255.255.252
interface Ethernet2/4
 description To_gonghang
 ip address 192.168.168.9 255.255.255.252
interface NULL0
interface Ethernet2/1
 port link-mode bridge
interface Ethernet2/5
interface Ethernet2/6
interface Ethernet2/7
interface Ethernet2/8
interface GigabitEthernet0/0
 description To_renhang
 combo enable copper
 ip address 192.168.168.1 255.255.255.252
interface GigabitEthernet0/1
 combo enable copper
 ip address 10.56.84.21 255.255.255.224
interface GigabitEthernet0/2
 scheduler logfile size 16
line class aux
 user-role network-admin
line class tty
 user-role network-operator
line class vty
line aux 0
 authentication-mode password
 set authentication password hash $h$6$uSCYMsor3YZOiNHh$9QWnbSqU2VJ7B0jtt/SAJeeq
2rL4Y8f6Coi2u3kMjHcevX2sX+g2mvV6v9hX99zjLwb5ZQVl0vADNsnz1H0h1A==
line vty 0 63
 ip route-static 145.0.241.0 24 192.168.168.18
 ip route-static 192.168.1.0 30 192.168.168.2
 ip route-static 192.168.2.0 24 192.168.168.6
 ip route-static 192.168.3.0 24 192.168.168.10
 ip route-static 192.168.4.0 24 192.168.168.14
 ip route-static 192.168.5.0 24 192.168.168.18
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
return
现更换用途,清空原有配置,使用命令如下图:
现路由器无法正常启动,启动后超级终端显示内容如下:
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test
Do you want to check SDRAM? [Y/N]
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing....Done.
*                  H3C MSR36-40 BootWare, Version 1.43                     *
Copyright (c) 2004-2015 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Apr 10 2015
CPU ID              : 0x2
Memory Type         : DDR3 SDRAM
Memory Size         : 2048MB
BootWare Size       : 1024KB
Flash Size          : 8MB
cfa0 Size           : 247MB
CPLD Version        : 2.0
PCB Version         : 2.0
BootWare Validating...
Image program does not exist.
Password recovery capability is enabled.
Note: The current operating device is cfa0
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
现请教处理方法,盼尽快回复,谢谢!
寂东 九段
粉丝:225人 关注:3人
Image program does not exist 镜像文件没了,估计你的路由器被攻击了,被格式化了,重新下载镜像文件上传吧,下载地址:
http://www.h3c.com/cn/Service/Document_Software/Software_Download/Router/Catalog/MSR_G2/MSR_3610[20][20-DP][40][60]/
用户名:yx800   密码:01230123
粉丝:24人 关注:13人
可以选择6跳过当前配置启动试一下
==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Enter your choice(0-9): 6 Flag Set Success. ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Enter your choice(0-9): 然后?
gxliuhj 发表时间:2019-01-15
故障现象还在。。。。。。
