防火墙F1060 NTP时间同步问题
2019-01-29提问
  • 1收藏,3107浏览
配置如下,但防火墙配置时钟源为203.107.6.88,但display ntp status显示同步LOCAL,时间不同步,为什么?
[ZJ-NBHDSSC-FW-F1060-iStack-01]disp cur | include ntp
 clock protocol ntp context 1
 ntp-service enable
 ntp-service source Route-Aggregation1
 ntp-service refclock-master 2
 ntp-service unicast-server 203.107.6.88 source Route-Aggregation1
粉丝:26人 关注:2人
开启下debug ntp看下报文交换吧,看下是不是有acl限制。
*Jan 30 00:45:46:454 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/ACL: -COntext=1; Access restrict: 0x00000008. *Jan 30 00:45:46:454 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/AUTH: -COntext=1; Received a packet at 77246, from 203.107.6.88, mode 4, key ID 00000000, length 48, authentication result 0 *Jan 30 00:45:46:454 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/PARAM: -COntext=1; Clock filter param: number 8, offset -28773.545928, delay 0.024841, dispersion 0.004058, jitter 0.002101, burst 0 *Jan 30 00:45:46:454 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/SELECT: -COntext=1; endpoint -1, -28773.575340 *Jan 30 00:45:46:454 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/SELECT: -COntext=1; endpoint 0, -28773.545928 *Jan 30 00:45:46:454 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/SELECT: -COntext=1; endpoint 1, -28773.516515 *Jan 30 00:45:46:454 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/SELECT: -COntext=1; peer 203.107.6.88, offset -28773.545928, low -28773.575340, high -28773.516515, flags 00000401 *Jan 30 00:45:46:455 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/SELECT: -COntext=1; Survivor 203.107.6.88, distance 2.004050 *Jan 30 00:45:46:455 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/SELECT: -COntext=1; Combine offset 0.000000000, jitter 0.000001907 *Jan 30 00:45:46:455 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/SYNCH: -COntext=1; Synchronized to peer 127.127.1.0 *Jan 30 00:45:46:455 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/SELECT: -COntext=1; Clock update at 77246, sample 77186, session ID 32164, offset 0.000000 *Jan 30 00:45:46:455 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/ADJUST: -COntext=1; Reset clock state, time count difference 60, state 5->5, poll 6, count 0, offset 0.000 *Jan 30 00:45:46:455 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/ADJUST: -COntext=1; Adjust local clock: offset 0.000000000 jitter 0.000001907 freq 0.000 stab 0.000 poll 6 *Jan 30 00:45:50:428 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/REFCLOCK: -COntext=1; Reference clock sent a packet to 127.127.1.0 at 77250. *Jan 30 00:45:50:428 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/REFCLOCK: -COntext=1; Reference clock received a packet from 127.127.1.0 at 77250. *Jan 30 00:45:50:428 2019 ZJ-NBHDSSC-FW-F1060-iStack-01 NTP/7/PARAM: -COntext=1; Clock filter param: number 8, offset 0.000000, delay 0.000000, dispersion 0.000928, jitter 0.000002, burst 0
zhiliao_H2wx2 发表时间:2019-01-29
sunny 八段
粉丝:9人 关注:0人
防火墙的域间策略放通了么?
放通了,可以ping通 203.107.6.88,disp ntp sessions也显示offset有数据的啊
zhiliao_H2wx2 知了小白
解决了,ntp-service refclock-master 2 这个改成ntp-service refclock-master 4  ,当服务器端的时钟层数大于或等于客户端的时钟层数时,客户端将不会与其同步。
