版本链接:
http://sso.h3c.com/LoginPage.aspx?Culture=zh-cn&RequestTicket=UwBhAG0AcABsAGUAUwBpAHQAZQA%3d%24aAB0AHQAcAA6AC8ALwB3AHcAdwAuAGgAMwBjAC4AYwBvAG0ALwBjAG4ALwBkAF8AMgAwADEANQAxADEALwA4ADkANgA5ADcAMQBfADMAMAAwADAANQBfADQAMAAuAGgAdABtAA%3d%3d%24MgAwADEANwAtADEAMQAtADIAMgAgADIAMwA6ADIANgA6ADQAMwA%3d%24hW8v7WTIgWKxsfxOW2izgA%3d%3d
下载账户:yx800 密码:01230123 TFTP工具可以百度到
<WA2620i-AGN>ap-mode fat
Change working mode will reboot system, do you want to continue? [Y/N]:y
Change working mode to FAT (please ensure FAT app is present)? [Y/N]:y
=======================<EXTEND-BOOTWAREMENU>==================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Clear Super Password |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9): 3
===================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash |
|<1> Download Application Program To SDRAM And Run |
|<2> Update Main Application File |
|<3> Update Backup Application File |
|<4> Update Secure Application File |
|<5> Modify Ethernet Parameter |
|<0> Exit To Main Menu |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-5): 5
=================<ETHERNET PARAMETER SET>======================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |==================================================================
Protocol (FTP or TFTP) :ftp ftp
Load File Name :WA2600A-CMW520-R1308P11-FAT.bin
:wa2600a_fat.bin
Target File Name :WA2600A-CMW520-R1308P11-FAT.bin
:wa2600a_fat.bin
Server IP Address :192.168.20.1 192.168.20.1
Local IP Address :192.168.20.2 192.168.20.2
Gateway IP Address :0.0.0.0
FTP User Name :111111 111111
FTP User Password :111111 111111
Enter your choice(0-5): 2
Loading.....................................................................
...Done!
9090048 bytes downloaded!
Updating File flash:/wa2600a_fat.bin........................................
........................Done!
Enter your choice(0-5): 0
=============<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 1
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
只需要下个TFTP就可以了吗
不知道怎么弄 能在线教我吗 跪求
能方便加个微信吗
就是第一不会
