h3c radius telnet登录没有权限
2019-05-24提问
  • 1收藏,3658浏览
 radius环境是centos7+freeradius3.0,IP是10.9.4.11
 /etc/raddb/users内容如下:
 test Cleartext-Password := test
     Service-Type = Login-User,
     Login-Service = Telnet,
     H3C-Exec-Privilege = 3
 /etc/raddb/clients.conf内容如下:
client 10.0.0.0/8 {
     secret = Secret
     shortname = h3c
 以调试模式运行radius:
radiusd -X
 服务器上另开一终端测试如下:
 radtest test test 10.9.4.11 0 Secret
 Sent Access-Request Id 84 from 0.0.0.0:35239 to 10.9.4.11:1812 length 74
               User-Name = "test"
               User-Password = "test"
               NAS-IP-Address = 10.9.4.11
               NAS-Port = 0
               Message-Authenticator = 0x00
               Cleartext-Password = "test"
Received Access-Accept Id 84 from 10.9.4.11:1812 to 0.0.0.0:0 length 44
 交换机是H3C s5120v2,配置之前使用了reset sa重置设备。
 <H3C>dis version
 H3C Comware Software, Version 7.1.070, Release 6113
 有关radius配置如下:
radius scheme telnetlogin
 primary authentication 10.9.4.11
 key authentication simple Secret
 user-name-format without-domain
 nas-ip 10.9.4.2
 domain system
 authentication login radius-scheme telnetlogin local
 authorization login radius-scheme telnetlogin local
 accounting login none
 user-interface vty 0 4
 authentication-mode scheme
 交换机打开了调试模式:
 <H3C>debugging radius all
 <H3C>debugging telnet server
 <H3C>terminal monitor
 <H3C>terminal debugging
 当telnet登录时输入用户名和密码都是test,在交换机上能看到如下消息:
 *Jan 1 03:02:27:810 2013 H3C RADIUS/7/EVENT:
 Decoded reply packet successfully.
*Jan 1 03:02:27:810 2013 H3C RADIUS/7/PACKET:
     Service-Type=Login-User
     Login-Service=Telnet
     H3c-Exec-Privilege=3
*Jan 1 03:02:27:811 2013 H3C RADIUS/7/PACKET:
 02 ac 00 2c aa f2 87 f2 73 5f fc 7d af 22 d3 27
 41 aa 7a 7a 06 06 00 00 00 01 0f 06 00 00 00 00
 1a 0c 00 00 63 a2 1d 06 00 00 00 03
 *Jan 1 03:02:27:815 2013 H3C RADIUS/7/EVENT:
 PAM_RADIUS: Fetched authentication reply-data successfully, resultCode: 0
 PAM_RADIUS: Received authentication reply message, resultCode: 0
 *Jan 1 03:02:27:817 2013 H3C RADIUS/7/EVENT:
 Sent reply message successfully.
*Jan 1 03:02:27:818 2013 H3C RADIUS/7/EVENT:
 PAM_RADIUS: Processing RADIUS authorization.
*Jan 1 03:02:27:819 2013 H3C RADIUS/7/EVENT:
 PAM_RADIUS: RADIUS Authorization successfully.
%Jan 1 03:02:28:495 2013 H3C SHELL/5/SHELL_LOGIN: test logged in from 10.9.4.95.
 在radius服务器显示如下消息:
(1) Sent Access-Accept Id 172 from 10.9.4.11:1812 to 10.9.4.2:20045 length 0
(1) Service-Type = Login-User
(1) Login-Service = Telnet
(1) H3C-Exec-Privilege = 3
(1) Finished request
 但是telnet终端没有任何权限执行命令:
 login: test
Password:
<H3C>?
User view commands:
       erase            Alias for 'delete'
       exit               Alias for 'quit'
       no                Alias for 'undo'
       quit              Exit from current command view
       show            Alias for 'display'
       system-view Enter the System View
       write             Alias for 'save'
 <H3C>dis cur
 Permission denied.
<H3C>
 H3C-Exec-Privilege其值从0到15都试过了都不行,有高人指点下吗?
佚名 九段
粉丝:22人 关注:0人
像是权限没有下发成功,服务器侧有选择设备类型的选项吗,另外你试试Huawei-Exec-Privilege
yuren 九段
粉丝:16人 关注:3人
这是什么型号的设备呢,是不是本身就没多少命令呢
zhiliao_t3PFa 知了小白
二楼的,交换机的调试信息里有输出:
这是收到了下发的权限吧。怀疑 H3c-Exec-Privilege这个属性在v7的交换机中已经无效了。我又不知新版的是用什么属性来表示权限。
配置是参照这篇文章做的:
***.***/p/4358e9e47b0c
知了社区也有另一人提了同样的问题。
配鱼找猫 知了小白
大佬的问题解决了吗我也遇到这个问题了,就是华三V7权限非常低,字段要怎么写
