H3C MSR50-40
2017-12-22提问
  • 1收藏,1943浏览
[YDXT-SH-WW-MSR5040-01]? System view commands: aaa Specify AAA configuration acl Specify acl configuration information acsei Specify ACSEI(a method for exchanging information between ACFP client and ACFP server) configuration information archive Specify archive settings arp Specify ARP configuration information aspf-policy Specify ASPF(Application Specific Packet Filter) policy configuration information atm Create ATM class attack-defense Specify attack defense policy configuration information bandwidth-based-sharing Specify bandwidth based load-sharing mode bgp Border Gateway Protocol(BGP) blacklist Specify blacklist configuration information bridge Config Bridge set buzzer Buzzer call function clock Specify the system clock command-alias Specify command alias command-privilege Specify the command level configuration Specify configuration settings configure-user User currently editing the configuration connection-limit Specify connection limit configuration information controller Specify controller configuration view copyright-info Copyright information configuration cut Cut connection dar Specify DAR configuration information delete Delete function dhcp DHCP configuration subcommands dialer DCC module dialer-rule Create a dialer-rule display Display current system information dlsw Specify DLSw(Data Link Switching) configuration information dns Specify domain name system domain Add domain or modify domain attributes dot1x Specify 802.1X configuration information error-diffusion Error packets diffusing in CE1/CT1 channels etofr Create a translation of an Ethernet interface to FR interface etoppp Create a translation of an Ethernet interface to PPP interface execute Batch Command file Specify file system configuration information firewall Specify firewall configuration information flow-interval Set interval of interface statistic fr Configure FR parameters ftp Specify FTP configuration information gratuitous-arp-learning Gratuitous Arp learning function gratuitous-arp-sending Sending gratuitous-arp packet when receiving different sub-network arp packet function header Specify the login banner hotkey Specify hotkey configuration information hwtacacs Specify HWTACACS server igmp Specify IGMP configuration information ike Specify IKE(Internet Key Exchange) configuration information info-center Specify information center configuration information interface Specify the interface configuration view ip Specify IP configurations for the system ipsec Specify IPSec(IP Security) configuration information ipv6 Enable IPv6 functionality isdn Specify ISDN configuration information job Schedule a system task l2tp Specify L2TP(Layer Two Tunneling Protocol) configuration information l2tp-group Specify L2TP(Layer Two Tunneling Protocol) group configuration information l2tpmoreexam L2tp command group local-user Specify local user configuration information logfile Specify log file configuration loopback-detection Detect if loopback exists mac-address Configure MAC address mib-style MIB style mirroring-group Specify mirroring-group mld Specify MLD configuration information msdp Specify MSDP(Multicast Source Discovery Protocol) configuration information mtracert Trace route to multicast source multicast Specify multicast configuration information nat Specify NAT(Network Address Translation) configuration information naturemask-arp Specify Nature Mask Arp function nqa Specify NQA (Network Quality Analyzer) configuration information ntp-service Specify NTP(Network Time Protocol) configuration information ospf Open Shortest Path First (OSPF) password-control Specify password control patch Specify patch configuration information pim Specify PIM(Protocol Independent Multicast) configuration information ping Ping function pki Specify PKI module configuration information policy-based-route Specify a policy based routing port Specify Port characteristics port-group Port group portal Portal protocol ppp Specify PPP(the Point-to-Point Protocol) configuration information pppoe-server Specify PPPoE(PPP over Ethernet) server configuration information public-key Specify public-key module configuration information qos Command of QoS(Quality of Service) quit Exit from current command view radius Specify RADIUS configuration information return Exit to User View rip Specify RIP(Routing Information Protocol) configuration information rmon Specify RMON route-policy Route-policy router Configure Router information sampler Sampler feature save Save current configuration service Toggle service mode. By default it is off sftp Specify SFTP service attribute shutdown-interval ShutDown Detection snmp-agent Specify SNMP(Simple Network Management Protocol) configuration information ssh Specify SSH (secure shell) configuration information standby Specify standby configuration information stp Spanning tree protocol super Specify super configuration information sysname Specify the host name system-failure System failure handling method tcp Specify TCP(Transmission Control Protocol) configuration information telnet Specify TELNET configuration information temperature-alarm Temperature alarm function temperature-limit Set temperature limit tftp Specify TFTP configuration information tftp-server TFTP Server time-range Specify time-range configuration information tracert Trace route function track Specify track information traffic Specify traffic configuration information transceiver Transceiver information translate Translation command between X.25 and TCP tunnel Tunnel interface udp-helper UDP HELPER module undo Cancel current setting user-group Specify user group configuration information user-interface Configure the user terminal interface userlog Userlog feature vlan Configure VLAN voice Specify voice VLAN vrrp Specify configuration information of VRRP x25 X.25 protocol x29 X.29 protocol [YDXT-SH-WW-MSR5040-01] [YDXT-SH-WW-MSR5040-01] [YDXT-SH-WW-MSR5040-01] [YDXT-SH-WW-MSR5040-01] [YDXT-SH-WW-MSR5040-01] [YDXT-SH-WW-MSR5040-01] [YDXT-SH-WW-MSR5040-01] [YDXT-SH-WW-MSR5040-01]
123 四段
实验室的MSR的V5设备全局下有这个LLDP enable命令,确定这个设备是MSRV5的版本就升级到最新的版本看下吧
粉丝:38人 关注:5人
哥们,你翻译下我看看,也不排版,你没做限速吗
