7003E+IMC+MACvlan认证
2019-11-13提问
  • 1收藏,1083浏览
[hx]%Nov 13 21:10:56:067 2019 hx DHCPR/3/DHCPR_SERVERCHANGE:
 Switched to the DHCP server at 10.5.7.20 because the current DHCP server did not respond.
%Nov 13 21:11:11:268 2019 hx DHCPR/3/DHCPR_SERVERCHANGE:
 Switched to the DHCP server at 10.5.7.10 because the current DHCP server did not respond.
interface Vlan-interface699
 ip address 10.16.99.1 255.255.255.0
 dhcp select relay
 dhcp relay server-address algorithm master-backup
 dhcp relay server-address 10.5.7.10
 dhcp relay server-address 10.5.7.20
interface Vlan-interface799
 ip address 10.17.99.1 255.255.255.0
 dhcp select relay
interface Bridge-Aggregation14
 port link-type hybrid
 port hybrid vlan 1 untagged
 mac-vlan enable
 stp edged-port
 mac-authentication
 loopback-detection enable vlan 1 to 4094
interface GigabitEthernet1/0/14
 port link-mode bridge
 port link-aggregation group 14
radius scheme 2000
 primary authentication 10.5.6.25
 primary accounting 10.5.6.25
 key authentication cipher $c$3$ML2XIBPz+BrLDOweUgObG6Wb7VAh/w==
 key accounting cipher $c$3$VCFSCcODFKkuvjUPpa9SbMKH6CRu+g==
 user-name-format without-domain
 # radius scheme system
 # domain imc authentication lan-access radius-scheme 2000
 authorization lan-access radius-scheme 2000
 accounting lan-access radius-scheme 2000
 # domain system
 # domain default enable imc
核心交换机上可以ping通10.5.7.10和10.5.7.20,不知道是啥原因,原来是S5800做核心,5120做汇聚,现在用7003e做核心,5500v2做汇聚,网络都是通的,原来的IMC和mac-vlan认证都是正常的,换了交换机就出现这个提示,会是哪个地方出问题啊。
连接
粉丝:15人 关注:0人
日志提示大概是:
因为DHCP中继无法从当前的DHCP服务器得到应答,所以DHCP中继切换到下一台指定VPN内的DHCP服务器申请IP地址。
指定的vpn?我没有配置VPN呢。
zhiliao_cxvfu 发表时间:2019-11-13
贴换到下一个服务器
zhiliao_pdGY6 发表时间:2019-11-13
想了解下,为什么DHCP服务器不应答,换了另外一个交换机就没有问题,是不是IMC有交换机的认证?
这个可以测试服务器看一下服务器是否还正常
