BOOT MENU
1. Download application file to flash
2. Select application file to boot 3. Display all files in flash 4. Delete file from flash 5. Restore to factory default configuration 6. Enter BootRom upgrade menu 7. Skip current system configuration 8. Reserved 9. Set switch startup mode
0. Reboot
Ctrl+F: Format File System
Ctrl+P: Skip Super Password
Ctrl+R: Download application to SDRAM and Run
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Crl+C: Display Copyright Enter your choice(0-9): 2
1. Set application file
2. Set configuration file
0. Return to boot menu Enter your choice(0-2): 1
File Number File Size(bytes) File Name ===============================================================================
No right Application file in the current device! BOOT MENU
(0)
这部分信息只能看出flash中没有bin文件,重新导入试试呢?不行的话重启进行内存检测,检测正常的话,格式化flash再导入,都不行的话可能设备有硬件故障了
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
Enter your choice(0-9): 0 Starting...... Press Ctrl+D to access BASIC BOOT MENU Press Ctrl+T to start memory test Memory test......... 123813608 bytes memory test ok. Memory test succeeded. ************************************************************************ * * * H3C S3100V2-26TP-PWR-EI BOOTROM, Version 118 * * * ************************************************************************ Copyright (c) 2004-2012 Hangzhou H3C Technologies Co., Ltd. Creation Date : Dec 27 2012,11:50:32 CPU Clock Speed : 200MHz Memory Size : 128MB Flash Size : 16MB CPLD Version : 003 PCB Version : Ver.A Mac Address : 000FE283070F Formatting flash............................................................... ...................................... Application program does not exist. BootRom password: Not required. Please press Enter to continue.
内存没有事,代表什么,,,测完或开机,,显示Formatting flash....什么意思
