接—EPON组网,同一网段不同onu之间可以互访,但是第三方软件无法搜索到终端设备。
2024-02-20提问
  • 0收藏,196浏览
粉丝:1人 关注:2人
目前碰到一个问题,某学校使用华三epon光网,一个电脑教室内有两台onu,一台8口一台24口,学生机分散连接在这两台onu上,教室电脑安装有智能课堂软件。当教师机连接在8口onu上时,所有学生机都可以搜索到教师机;但是当教师机连接到24口onu上后,所有学生机都无法搜索到教师机,但是此时icmp连通性是正常的,请问是什么问题导致的?
粉丝:1人 关注:2人
#(IGMP的配置没有效果,还没删完)
version 7.1.070, Release 7639P03
mdc Admin id 1
sysname Core
telnet server enable
forward-path-detection enable
irf mac-address persistent always
irf auto-update enable
irf auto-merge enable
undo irf link-delay
irf member 1 priority 32
irf member 2 priority 15
irf mode normal
track 1 nqa entry to_fw s1 reaction 1
ip unreachables enable
ip ttl-expires enable
igmp-snooping
undo ip fast-forwarding load-sharing
dhcp enable
dhcp server forbidden-ip 10.23.8.251
dns server 211.136.192.6
lldp global enable
system-working-mode standard
xbar chassis 1 load-balance
xbar chassis 2 load-balance
vlan 1
vlan 3
description Guangbo
vlan 10
igmp-snooping enable
vlan 100
description Wlan_YeWu
vlan 101
vlan 102
vlan 4000
description SW_Management
vlan 4001
description AP_Management
vlan 4002
description Server
irf-port 1/2
port group interface Ten-GigabitEthernet1/2/0/47 mode enhanced
port group interface Ten-GigabitEthernet1/2/0/48 mode enhanced
irf-port 2/1
port group interface Ten-GigabitEthernet2/2/0/47 mode enhanced
port group interface Ten-GigabitEthernet2/2/0/48 mode enhanced
vlan-group Wlan
vlan-list 100 to 102
stp instance 0 root primary
stp port-log instance 0 to 4094
stp port-log vlan 1 to 4094
stp global enable
ftth
onu upstream-sla maximum-bandwidth percent 80
fiber-backup group 1
fiber-backup group 2
fiber-backup group 3
fiber-backup group 4
fiber-backup group 5
fiber-backup group 6
fiber-backup group 7
fiber-backup group 8
fiber-backup group 9
fiber-backup group 10
fiber-backup group 11
fiber-backup group 12
onu bind auto chassis 1 slot 0
onu bind auto chassis 1 slot 1
onu bind auto chassis 2 slot 0
onu bind auto chassis 2 slot 1
dhcp server ip-pool vlan10
gateway-list 10.23.8.254
network 10.23.8.0 mask 255.255.255.0
dns-list 211.136.192.6 223.5.5.5
network 10.33.8.0 mask 255.255.255.0 secondary
gateway-list 10.33.8.254
network 10.53.8.0 mask 255.255.255.0 secondary
gateway-list 10.53.8.254
dhcp server ip-pool vlan100
gateway-list 192.169.100.254
network 192.169.100.0 mask 255.255.255.0
dhcp server ip-pool vlan101
gateway-list 192.169.101.254
network 192.169.101.0 mask 255.255.255.0
dhcp server ip-pool vlan102
gateway-list 192.169.102.254
network 192.169.102.0 mask 255.255.255.0
dhcp server ip-pool vlan4001
gateway-list 172.17.0.254
network 172.17.0.0 mask 255.255.255.0
option 43 hex 8007000001ac1000fa
policy-based-route TO_FW permit node 10
if-match acl 3000
apply next-hop 10.1.1.2 track 1
nqa entry to_fw s1
type icmp-echo
destination ip 10.1.1.2
frequency 1000
probe timeout 500
reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
nqa schedule to_fw s1 start-time now lifetime forever
interface NULL0
interface Vlan-interface1
local-proxy-arp enable
interface Vlan-interface3
description Guangbo
ip address 192.168.3.1 255.255.255.0
ip policy-based-route TO_FW
interface Vlan-interface10
ip address 10.23.8.254 255.255.255.0
ip address 10.33.8.254 255.255.255.0 sub
ip address 10.53.8.254 255.255.255.0 sub
interface Vlan-interface100
ip address 192.169.100.254 255.255.255.0
interface Vlan-interface101
ip address 192.169.101.254 255.255.255.0
interface Vlan-interface102
ip address 192.169.102.254 255.255.255.0
interface Vlan-interface4000
ip address 172.16.0.254 255.255.255.0
interface Vlan-interface4001
ip address 172.17.0.254 255.255.255.0
interface Vlan-interface4002
description Server
ip address 172.18.0.254 255.255.255.0
interface GigabitEthernet1/2/0/1
port link-mode bridge
description TO_AC-GE1/0/1
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 100 to 102 4000
interface GigabitEthernet1/2/0/2
interface GigabitEthernet1/2/0/3
description TO_FW-MGE0/0/0
port access vlan 4000
interface GigabitEthernet1/2/0/4
interface GigabitEthernet1/2/0/5
interface GigabitEthernet1/2/0/6
interface GigabitEthernet1/2/0/7
interface GigabitEthernet1/2/0/8
interface GigabitEthernet1/2/0/9
interface GigabitEthernet1/2/0/10
interface GigabitEthernet1/2/0/11
interface GigabitEthernet1/2/0/12
interface GigabitEthernet1/2/0/13
port access vlan 10
interface GigabitEthernet1/2/0/14
port access vlan 10
interface GigabitEthernet1/2/0/15
port access vlan 10
interface GigabitEthernet1/2/0/16
port access vlan 10
interface GigabitEthernet1/2/0/17
interface GigabitEthernet1/2/0/18
interface GigabitEthernet1/2/0/19
interface GigabitEthernet1/2/0/20
interface GigabitEthernet1/2/0/21
interface GigabitEthernet1/2/0/22
interface GigabitEthernet1/2/0/23
interface GigabitEthernet1/2/0/24
interface GigabitEthernet1/2/0/25
interface GigabitEthernet1/2/0/26
interface GigabitEthernet1/2/0/27
interface GigabitEthernet1/2/0/28
interface GigabitEthernet1/2/0/29
interface GigabitEthernet1/2/0/30
interface GigabitEthernet1/2/0/31
interface GigabitEthernet1/2/0/32
interface GigabitEthernet1/2/0/33
interface GigabitEthernet1/2/0/34
interface GigabitEthernet1/2/0/35
interface GigabitEthernet1/2/0/36
interface GigabitEthernet1/2/0/37
interface GigabitEthernet1/2/0/38
interface GigabitEthernet1/2/0/39
interface GigabitEthernet1/2/0/40
interface GigabitEthernet1/2/0/41
interface GigabitEthernet1/2/0/42
interface GigabitEthernet1/2/0/43
interface GigabitEthernet1/2/0/44
interface GigabitEthernet2/2/0/1
description TO_IPS-GE1/0/1
interface GigabitEthernet2/2/0/2
description TO_IPS-MGE0/0/0
interface GigabitEthernet2/2/0/3
interface GigabitEthernet2/2/0/4
interface GigabitEthernet2/2/0/5
interface GigabitEthernet2/2/0/6
interface GigabitEthernet2/2/0/7
interface GigabitEthernet2/2/0/8
interface GigabitEthernet2/2/0/9
interface GigabitEthernet2/2/0/10
interface GigabitEthernet2/2/0/11
interface GigabitEthernet2/2/0/12
interface GigabitEthernet2/2/0/13
interface GigabitEthernet2/2/0/14
interface GigabitEthernet2/2/0/15
interface GigabitEthernet2/2/0/16
interface GigabitEthernet2/2/0/17
interface GigabitEthernet2/2/0/18
interface GigabitEthernet2/2/0/19
interface GigabitEthernet2/2/0/20
interface GigabitEthernet2/2/0/21
interface GigabitEthernet2/2/0/22
interface GigabitEthernet2/2/0/23
interface GigabitEthernet2/2/0/24
port access vlan 100
interface GigabitEthernet2/2/0/25
interface GigabitEthernet2/2/0/26
interface GigabitEthernet2/2/0/27
interface GigabitEthernet2/2/0/28
interface GigabitEthernet2/2/0/29
interface GigabitEthernet2/2/0/30
interface GigabitEthernet2/2/0/31
interface GigabitEthernet2/2/0/32
interface GigabitEthernet2/2/0/33
interface GigabitEthernet2/2/0/34
interface GigabitEthernet2/2/0/35
interface GigabitEthernet2/2/0/36
interface GigabitEthernet2/2/0/37
interface GigabitEthernet2/2/0/38
interface GigabitEthernet2/2/0/39
interface GigabitEthernet2/2/0/40
interface GigabitEthernet2/2/0/41
interface GigabitEthernet2/2/0/42
interface GigabitEthernet2/2/0/43
interface GigabitEthernet2/2/0/44
interface M-GigabitEthernet1/0/0/0
interface M-GigabitEthernet1/0/0/1
interface Ten-GigabitEthernet1/0/0/13
interface Ten-GigabitEthernet1/0/0/14
interface Ten-GigabitEthernet1/0/0/15
interface Ten-GigabitEthernet1/0/0/16
interface Ten-GigabitEthernet1/0/0/17
interface Ten-GigabitEthernet1/0/0/18
interface Ten-GigabitEthernet1/0/0/19
interface Ten-GigabitEthernet1/0/0/20
interface Ten-GigabitEthernet1/1/0/1
interface Ten-GigabitEthernet1/1/0/2
interface Ten-GigabitEthernet1/2/0/45
interface Ten-GigabitEthernet1/2/0/46
interface Ten-GigabitEthernet2/0/0/13
interface Ten-GigabitEthernet2/0/0/14
interface Ten-GigabitEthernet2/0/0/15
interface Ten-GigabitEthernet2/0/0/16
interface Ten-GigabitEthernet2/0/0/17
interface Ten-GigabitEthernet2/0/0/18
interface Ten-GigabitEthernet2/0/0/19
interface Ten-GigabitEthernet2/0/0/20
interface Ten-GigabitEthernet2/1/0/1
interface Ten-GigabitEthernet2/1/0/2
interface Ten-GigabitEthernet2/2/0/45
interface Ten-GigabitEthernet2/2/0/46
interface Olt1/0/0/1
description 3F
using onu 1 to 8
port fiber-backup group 10
port link-type hybrid
port hybrid vlan 3 10 4001 tagged
port hybrid vlan 1 untagged
interface Olt1/0/0/2
using onu 1 to 8
interface Olt1/0/0/3
using onu 1 to 8
interface Olt1/0/0/4
using onu 1 to 8
interface Olt1/0/0/5
using onu 1 to 8
interface Olt1/0/0/6
using onu 1 to 8
interface Olt1/0/0/7
using onu 1 to 8
interface Olt1/0/0/8
using onu 1 to 8
interface Olt1/0/0/9
using onu 1 to 8
interface Olt1/0/0/10
interface Olt1/0/0/11
interface Olt1/0/0/12
interface Olt1/1/0/1
description -1F-A
using onu 1 to 16
interface Olt1/1/0/2
description -1F-B
using onu 1 to 9
port fiber-backup group 2
interface Olt1/1/0/3
description 1F
using onu 1 to 8
port fiber-backup group 3
interface Olt1/1/0/4
description Jiankongshi
using onu 1 to 8
port fiber-backup group 4
interface Olt1/1/0/5
description 2F-A
using onu 1 to 16
port fiber-backup group 5
interface Olt1/1/0/6
description 2F-B
using onu 1 to 8
port fiber-backup group 6
interface Olt1/1/0/7
description 3F
using onu 1 to 10
port fiber-backup group 7
interface Olt1/1/0/8
description 5F-A
using onu 1 to 9
port fiber-backup group 8
interface Olt1/1/0/9
description 5F-B
using onu 1 to 8
port fiber-backup group 9
interface Olt1/1/0/10
interface Olt1/1/0/11
interface Olt1/1/0/12
interface Olt1/1/0/13
using onu 1
interface Olt1/1/0/14
interface Olt1/1/0/15
using onu 1 to 3
interface Olt1/1/0/16
interface Olt1/1/0/17
interface Olt1/1/0/18
interface Olt1/1/0/19
interface Olt1/1/0/20
interface Olt1/1/0/21
interface Olt1/1/0/22
interface Olt1/1/0/23
interface Olt1/1/0/24
interface Olt2/0/0/1
shutdown
using onu 1 to 8
interface Olt2/0/0/2
using onu 1 to 8
interface Olt2/0/0/3
using onu 1 to 8
interface Olt2/0/0/4
using onu 1 to 8
interface Olt2/0/0/5
using onu 1 to 8
interface Olt2/0/0/6
using onu 1 to 8
interface Olt2/0/0/7
using onu 1 to 8
interface Olt2/0/0/8
using onu 1 to 8
interface Olt2/0/0/9
using onu 1 to 8
interface Olt2/0/0/10
interface Olt2/0/0/11
interface Olt2/0/0/12
interface Olt2/1/0/1
description -1F-A
shutdown
using onu 1 to 16
interface Olt2/1/0/2
description -1F-B
shutdown
using onu 1 to 8
interface Olt2/1/0/3
description 1F
shutdown
using onu 1 to 8
interface Olt2/1/0/4
shutdown
using onu 1 to 8
interface Olt2/1/0/5
description 2F-A
shutdown
using onu 1 to 8
interface Olt2/1/0/6
description 2F-B
shutdown
using onu 1 to 8
interface Olt2/1/0/7
description 3F
shutdown
using onu 1 to 8
interface Olt2/1/0/8
description 5F-A
shutdown
using onu 1 to 9
interface Olt2/1/0/9
description 5F-B
shutdown
using onu 1 to 8
interface Olt2/1/0/10
interface Olt2/1/0/11
interface Olt2/1/0/12
interface Olt2/1/0/13
interface Olt2/1/0/14
interface Olt2/1/0/15
interface Olt2/1/0/16
interface Olt2/1/0/17
interface Olt2/1/0/18
interface Olt2/1/0/19
interface Olt2/1/0/20
interface Olt2/1/0/21
interface Olt2/1/0/22
interface Olt2/1/0/23
interface Olt2/1/0/24
interface Onu1/0/0/1:1
bind onu-id 9c09-710d-e78c
uni 1 vlan-mode tag pvid 3
uni 2 vlan-mode tag pvid 10
uni 3 vlan-mode tag pvid 10
uni 4 vlan-mode tag pvid 10
uni 5 vlan-mode tag pvid 10
uni 6 vlan-mode tag pvid 10
uni 7 vlan-mode tag pvid 10
uni 8 vlan-mode tag pvid 10
port trunk permit vlan 3 10 4001
interface Onu1/0/0/1:2
bind onu-id 34dc-99c2-2b53
interface Onu1/0/0/1:3
bind onu-id 9c09-710d-e756
uni 1 vlan-mode tag pvid 4001
uni 2 vlan-mode tag pvid 4001
uni 3 vlan-mode tag pvid 4001
uni 4 vlan-mode tag pvid 4001
uni 5 vlan-mode tag pvid 4001
uni 6 vlan-mode tag pvid 4001
uni 7 vlan-mode tag pvid 4001
uni 8 vlan-mode tag pvid 4001
interface Onu1/0/0/1:4
bind onu-id c407-784c-968d
interface Onu1/0/0/1:5
bind onu-id 9c09-710d-ccbc
uni 1 vlan-mode tag pvid 10
uni 9 vlan-mode tag pvid 10
uni 10 vlan-mode tag pvid 10
uni 11 vlan-mode tag pvid 10
uni 12 vlan-mode tag pvid 10
uni 13 vlan-mode tag pvid 10
uni 14 vlan-mode tag pvid 10
uni 15 vlan-mode tag pvid 10
uni 16 vlan-mode tag pvid 10
uni 17 vlan-mode tag pvid 10
uni 18 vlan-mode tag pvid 10
uni 19 vlan-mode tag pvid 10
uni 20 vlan-mode tag pvid 10
uni 21 vlan-mode tag pvid 10
uni 22 vlan-mode tag pvid 10
uni 23 vlan-mode tag pvid 10
uni 24 vlan-mode tag pvid 10
interface Onu1/0/0/1:6
bind onu-id 9c09-710d-c983
port trunk pvid vlan 10
interface Onu1/0/0/1:7
bind onu-id 9c09-710d-e7aa
interface Onu1/1/0/1:1
bind onu-id c407-784c-9691
interface Onu1/1/0/1:2
bind onu-id c407-784c-968a
interface Onu1/1/0/1:3
interface Onu1/1/0/1:4
interface Onu1/1/0/1:5
interface Onu1/1/0/1:6
interface Onu1/1/0/1:7
interface Onu1/1/0/1:8
bind onu-id 9c09-710d-e75f
interface Onu1/1/0/1:9
bind onu-id 34dc-99c2-2c40
interface Onu1/1/0/1:10
bind onu-id c407-784c-5987
interface Onu1/1/0/1:11
bind onu-id 9c09-710d-e7b9
interface Onu1/1/0/1:12
bind onu-id 9c09-710d-e780
interface Onu1/1/0/1:13
bind onu-id c407-784c-9682
interface Onu1/1/0/1:14
bind onu-id c407-784c-9693
interface Onu1/1/0/1:15
bind onu-id c407-784c-968b
interface Onu1/1/0/1:16
bind onu-id c407-784c-968c
interface Onu1/1/0/2:1
interface Onu1/1/0/2:2
bind onu-id 9c09-710d-f03b
interface Onu1/1/0/2:3
port trunk pvid vlan 4001
interface Onu1/1/0/2:4
bind onu-id 7c7a-3c15-9862
interface Onu1/1/0/2:5
interface Onu1/1/0/2:6
interface Onu1/1/0/2:7
interface Onu1/1/0/2:8
interface Onu1/1/0/2:9
interface Onu1/1/0/3:1
interface Onu1/1/0/3:2
bind onu-id 9c09-710d-e7bc
uni 6 vlan-mode tag pvid 3
uni 7 vlan-mode tag pvid 3
uni 8 vlan-mode tag pvid 3
interface Onu1/1/0/3:3
bind onu-id 34dc-99d5-3f17
interface Onu1/1/0/3:4
bind onu-id c407-784c-9687
interface Onu1/1/0/3:5
bind onu-id c407-784c-9689
interface Onu1/1/0/3:6
bind onu-id c407-784c-9685
interface Onu1/1/0/3:7
bind onu-id c407-784c-9692
interface Onu1/1/0/3:8
bind onu-id c407-784c-9690
interface Onu1/1/0/4:1
bind onu-id 7c7a-3c15-9426
uni 2 vlan-mode tag pvid 3
uni 3 vlan-mode tag pvid 3
uni 4 vlan-mode tag pvid 3
uni 5 vlan-mode tag pvid 3
interface Onu1/1/0/4:2
interface Onu1/1/0/4:3
interface Onu1/1/0/4:4
interface Onu1/1/0/4:5
interface Onu1/1/0/4:6
interface Onu1/1/0/4:7
interface Onu1/1/0/4:8
interface Onu1/1/0/5:1
interface Onu1/1/0/5:2
bind onu-id c407-784c-968e
interface Onu1/1/0/5:3
bind onu-id c407-784c-9686
interface Onu1/1/0/5:4
bind onu-id c407-784c-9688
interface Onu1/1/0/5:5
bind onu-id c407-784c-9680
interface Onu1/1/0/5:6
bind onu-id c407-784c-968f
interface Onu1/1/0/5:7
bind onu-id c407-784c-9681
interface Onu1/1/0/5:8
bind onu-id c407-784c-9684
interface Onu1/1/0/5:9
interface Onu1/1/0/5:10
interface Onu1/1/0/5:11
interface Onu1/1/0/5:12
interface Onu1/1/0/5:13
interface Onu1/1/0/5:14
interface Onu1/1/0/5:15
interface Onu1/1/0/5:16
interface Onu1/1/0/6:1
bind onu-id 1484-7795-7fb2
interface Onu1/1/0/6:2
interface Onu1/1/0/6:3
interface Onu1/1/0/6:4
interface Onu1/1/0/6:5
interface Onu1/1/0/6:6
interface Onu1/1/0/6:7
interface Onu1/1/0/6:8
interface Onu1/1/0/7:1
interface Onu1/1/0/7:2
interface Onu1/1/0/7:3
interface Onu1/1/0/7:4
interface Onu1/1/0/7:5
interface Onu1/1/0/7:6
interface Onu1/1/0/7:7
interface Onu1/1/0/7:8
interface Onu1/1/0/7:9
interface Onu1/1/0/7:10
interface Onu1/1/0/8:1
bind onu-id 9c09-710d-e792
interface Onu1/1/0/8:2
bind onu-id 9c09-710d-e7ce
interface Onu1/1/0/8:3
bind onu-id c407-784c-9835
interface Onu1/1/0/8:4
bind onu-id 34dc-99c2-2f28
interface Onu1/1/0/8:5
bind onu-id c407-784c-9683
interface Onu1/1/0/8:6
bind onu-id 9c09-710d-e750
interface Onu1/1/0/8:7
bind onu-id 9c09-710d-e774
interface Onu1/1/0/8:8
bind onu-id 9c09-710d-e7ad
interface Onu1/1/0/8:9
interface Onu1/1/0/9:1
bind onu-id 34dc-99c2-2b1d
interface Onu1/1/0/9:2
bind onu-id 34dc-99d5-3ef6
interface Onu1/1/0/9:3
bind onu-id 9c09-710d-e7a1
interface Onu1/1/0/9:4
bind onu-id 34dc-99c2-2e14
interface Onu1/1/0/9:5
bind onu-id 9c09-710d-e79e
interface Onu1/1/0/9:6
interface Onu1/1/0/9:7
interface Onu1/1/0/9:8
interface Onu1/1/0/13:1
interface Onu1/1/0/15:1
interface Onu1/1/0/15:2
interface Onu1/1/0/15:3
interface Onu2/0/0/1:1
interface Onu2/0/0/1:2
interface Onu2/0/0/1:3
interface Onu2/0/0/1:4
interface Onu2/0/0/1:5
interface Onu2/0/0/1:6
interface Onu2/0/0/1:7
interface Onu2/1/0/1:8
interface Onu2/1/0/1:9
interface Onu2/1/0/1:10
interface Onu2/1/0/1:11
interface Onu2/1/0/1:12
interface Onu2/1/0/1:13
interface Onu2/1/0/1:14
interface Onu2/1/0/1:15
interface Onu2/1/0/1:16
interface Onu2/1/0/2:1
interface Onu2/1/0/2:2
interface Onu2/1/0/2:3
interface Onu2/1/0/2:4
interface Onu2/1/0/2:5
interface Onu2/1/0/2:6
interface Onu2/1/0/2:7
interface Onu2/1/0/2:8
interface Onu2/1/0/3:1
interface Onu2/1/0/3:2
interface Onu2/1/0/3:3
interface Onu2/1/0/3:4
interface Onu2/1/0/3:5
interface Onu2/1/0/3:6
interface Onu2/1/0/3:7
interface Onu2/1/0/3:8
interface Onu2/1/0/4:1
interface Onu2/1/0/4:2
interface Onu2/1/0/4:3
interface Onu2/1/0/4:4
interface Onu2/1/0/4:5
interface Onu2/1/0/4:6
interface Onu2/1/0/4:7
interface Onu2/1/0/4:8
interface Onu2/1/0/5:1
interface Onu2/1/0/5:2
interface Onu2/1/0/5:3
interface Onu2/1/0/5:4
interface Onu2/1/0/5:5
interface Onu2/1/0/5:6
interface Onu2/1/0/5:7
interface Onu2/1/0/5:8
interface Onu2/1/0/6:1
interface Onu2/1/0/8:1
interface Onu2/1/0/8:2
interface Onu2/1/0/8:3
interface Onu2/1/0/8:4
interface Onu2/1/0/8:5
interface Onu2/1/0/8:6
interface Onu2/1/0/8:7
interface Onu2/1/0/8:8
interface Onu2/1/0/8:9
interface Onu2/1/0/9:1
interface Onu2/1/0/9:2
interface Onu2/1/0/9:3
interface Onu2/1/0/9:4
interface Onu2/1/0/9:5
interface Onu2/1/0/9:6
interface Onu2/1/0/9:7
interface Onu2/1/0/9:8
multicast routing
pim
igmp
scheduler logfile size 16
line class aux
user-role network-admin
line class vty
user-role network-operator
line aux 1/0 2/1
line vty 0 63
authentication-mode scheme
ip route-static 0.0.0.0 0 172.16.0.252
ip route-static 172.16.0.252 32 10.1.1.5
ssh server enable
arp ip-conflict log prompt
arp user-ip-conflict record enable
acl advanced 3000
rule 0 permit ip
undo password-control length enable
domain system
domain wa
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
password hash $h$6$CJvkDnlNDFxXke0w$O9jpkFfIkx7Fg0CdGW+yw8+JSLTBJWCeTTlyIlvoZjF73/QBs67T7vQ/AsMCg4h0dTChstMG24n5n577Sm8IGg==
service-type telnet http ssh
authorization-attribute user-role level-15
security-enhanced level 1
undo ssl renegotiation disable
undo ssl version ssl3.0 disable
undo ssl version tls1.0 disable
undo ssl version tls1.1 disable
cloud-management server domain oasis.h3c.com
return
