堆叠做不起来
拓扑如下
switch1 通过XGE 1/0/49 链接 switch2 XGE 1/0/52
switch1 通过XGE 1/0/50 链接 switch2 XGE 1/0/51
switch1 配置
sys
irf member 1 priority 31
interface range Ten-GigabitEthernet 1/0/49 to Ten-GigabitEthernet 1/0/50
shutdwon
exit
irf-port 1/1
port group interface Ten-GigabitEthernet 1/0/49
port group interface Ten-GigabitEthernet 1/0/50
exit
exit
irf-port-configuration active
switch2配置
sys
irf member 1 renumber 2
exit save
reboot
sys
interface range Ten-GigabitEthernet 2/0/51 to Ten-GigabitEthernet 2/0/52
shutdwon
exit
irf-port 2/2
port group interface Ten-GigabitEthernet 2/0/51
port group interface Ten-GigabitEthernet 2/0/52
exit
undo shutdwon
exit
(0)
第一台
配置成员优先级(irf member 1 priority x)
关闭irf物理端口(shutdown)
创建irf端口并绑定irf物理端口(port group interface Ten-GigabitEthernet x/x/x)
开启irf物理端口(undo shutdown)
保存(save)
重启(reboot)
激活irf(irf-port-configuration active)
第二台
配置成员编号(irf member 1 renumber x)
重启后生效(reboot)
关闭irf物理端口(shutdown)
保存(save)
重启(reboot)
接线
irf开始合并选举失败一方将自动重启
模拟器先接线再配置合并时会报错irf端口故障,而且irf物理端口会一直down
(0)
配置完成后端口不UP,需要保存后重启模拟器才可以堆叠成功。
(2台S5820V2-54QS)堆叠成功以下供参考
<sw01>dis cu
version 7.1.075, Alpha 7571
sysname sw01
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 32
irf member 2 priority 1
lldp global enable
system-working-mode standard
xbar load-single
password-recovery enable
lpu-type f-series
vlan 1
vlan 3
vlan 10 to 11
irf-port 1/1
port group interface Ten-GigabitEthernet1/0/49
port group interface Ten-GigabitEthernet1/0/50
irf-port 2/2
port group interface Ten-GigabitEthernet2/0/49
port group interface Ten-GigabitEthernet2/0/50
interface Bridge-Aggregation1
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 2 to 4094
interface Bridge-Aggregation2
interface NULL0
interface Vlan-interface3
mad bfd enable
mad ip address 10.100.10.1 255.255.255.0 member 1
mad ip address 10.100.10.2 255.255.255.0 member 2
interface Vlan-interface10
ip address 10.220.10.1 255.255.255.0
interface Vlan-interface11
ip address 10.220.11.1 255.255.255.0
interface FortyGigE1/0/53
port link-mode bridge
interface FortyGigE1/0/54
interface FortyGigE2/0/53
interface FortyGigE2/0/54
port access vlan 3
combo enable copper
undo stp enable
combo enable copper
port link-aggregation group 2
combo enable copper
port link-aggregation group 1
interface GigabitEthernet1/0/4
combo enable copper
interface GigabitEthernet1/0/5
combo enable copper
interface GigabitEthernet1/0/6
combo enable copper
interface GigabitEthernet1/0/7
combo enable copper
interface GigabitEthernet1/0/8
combo enable copper
interface GigabitEthernet1/0/9
---- More ----
(0)
shutdwon //shutdown不对啊,你可以试一试把irf-port改成1/2和2/1试一试
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
我先保存了下然后在激活,还是不行。
我按照您的方法试了一下,可以了。但是只有一个链路是起来,2个口只有一个起来了。另一个是DOWN的请问怎么破?
确认堆叠口是up的吗?
